Switching subs? (12"-10")
I mainly listen to metal, rock and some club/techno every once in a great while.
I'm wondering if a set of L5 or L7 10"s would still give me the low end.. But I don't want a "sloppy" speaker. I'm looking for sound quality and not really into slam anymore.
Kappa 10"s?? My stereo has been quite moody lately. I drive the car ~1-2x a week, and when I get in it on saturday it just seems really quiet, almost like the mid amp turned itself down or the loudness on the HU turned itself down..
No idea WTF is going on.
I have a decent dual amp setup now, but it's hidden under the darn box. Even though the t-top box has always been an attention getter and conversation piece at shows. It would bug me a little to get rid of it, but I'd also be dropping some serious weight without it.Kappa perfect 12's I have are a 98db sensitivity.... Maybe 400WRMS/Ch is all I am looking for. ~1000Wpeak.. The Kappas are around 200-500WRMS. Perfect hooked to a 500x2 amp.
I'm just gonna list some stuff...
http://www.kicker.com/Solo-Baric_L3
Solo L3 10"
SIZE [in, cm]: 10, 25
IMPEDANCE [Ohms]: 2 or 4 DVC
POWER WATTS [peak/RMS]: 800/400
SENSITIVITY [dB 1w/1m]: 85.3
MOUNTING DEPTH [in, cm]: 5-1/2, 14
MOUNTING DIAMETER [in, cm]: 9-5/16, 23.7
MIN SEALED BOX VOL [cu. ft, L]: 0.8, 22.7
MAX SEALED BOX VOL [cu. ft, L]: 3, 85
Solo L7 10"
Size (IN.,CM) 10, 25.4
Impedance (OHMS) 2 or 4 DVC
Max Rec Amplifier Power (WATTS PEAK/RMS)* 1200/600
Sensitivity (dB 1w/1m) 86.8
Frequency Response (Hz) 24-100
Mounting Depth (IN.,CM) 6-1/4, 15.9
Mounting Cutout, Square (IN.,CM) 9-5/16, 23.7
Min Rec Sealed Box Volume (CU. FT., Liters) .66, 18.7
Max Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3
You can use a single 10" sub and make big bass along with definition and clarity. You just have to use the right sub. There are several very good ones out there. I regularly use CDT, RE Audio, Massive Audio, JBL, and several others for big bass from a small sub. These are very tight sounding subs that make huge bass but can do it in a way that is controlled sounding and defined.
These are my favorite right now:
http://www.massiveaudio.com/store/po...bwoofer&area=C
These are an outstanding sub for the money and make big bass with good definition.
The CDT HD-1000CF is another outstanding sub I use alot but it is geared more toward sound quality and less on output. It still hits hard, just more focused.
I'm sure I gave enough info in my above response to give you a good idea of what I'm looking for.
Could you recomend me a decent 4 ch amp for my components? I've always had my eye on kicker 50.4, but No reason to. I just liked the fan-cooled and crossover adjustments.
And I take it a sealed box would still be the way to go to keep everything tight? Do you use any kind of sealant tape under the sub to aid this?
