Possible?
Old Jul 18, 2011 | 09:58 PM
Sladester2's Avatar
Default Possible?
I bought an aftermarket headunit for my trans am that also works with my steering wheel. My power antenna isn't working now, im not for sure if it was right after it was installed. Is there a possibility it does not work with the head unit or maybe the installer didn't hook it up right? It's a jvc I can't remember the exact model
Old Jul 19, 2011 | 12:27 AM
sjsingle1's Avatar
most head units have a wire to switch the power antenna.......check that wire out
Old Jul 19, 2011 | 03:07 PM
VIP1's Avatar
Copy & Paste Moderator
Also, many aftermarket headunits will only raise the antenna if you are listening to FM.
The antenna raise wire in the stock radio harness is pink.
Old Jul 19, 2011 | 05:36 PM
edobi21's Avatar
on some of the headunits, the power antenna wire is also the same you would use for an amp turn on.
Old Jul 19, 2011 | 11:24 PM
Sladester2's Avatar
Alright thanks. Im pretty sure the antenna itself isnt messed up because when i pull it up manually I can feel it pull itself back down. I have tried it in FM and still no difference, I am thinking a wire was left off
