Simple ground wire question
Old Jul 23, 2011 | 07:38 PM
stingrayj's Avatar
Default Simple ground wire question
I've read a number of posts and have not found a direct answer for my question which is...
Does the ground wire from my head unit have to go to a chasis ground or can it be grounded through the wire harness adapter?
I am currently wiring up an Alpine CDA-117 head unit wire harness to a Scosche GM02 (not GM02B...it's old). I am also wiring in a SWI-JACK adapter which also needs to be grounded. I was thinking that I could just cut the end off of the Alpine wire harness ground wire and tie all three ground wires (head unit, Scosche, SWI-JACK) together. This would then ground everything through the factory ground wire in the wire harness.
Old Jul 23, 2011 | 08:07 PM
DOUBLEDMODS's Avatar
Closed ex-Sponsor Account
to the harness ground is fine
Old Jul 23, 2011 | 08:10 PM
stingrayj's Avatar
Thanks! I just needed some confirmation.
