BCM Going out.
http://tinypic.com/r/20p8114/7
I opened up my bcm and it seems to have like a hairline crack on the bottom port. I made an illustration. If i solder it again, will it make this problem go away?
Heres my illustration. microsoft paint.
The dark line would be the hairline crack around the port.
It was a plug and play because once you turned on the ignition switched, It installed itself to your car settings, just like the old one you had.
Which wires are you referring to?
what could my options be? should I plug in a computer and find out if there is anything wrong with it?
