Need wiring layout
Old Aug 16, 2011 | 11:38 PM
Cosmos's Avatar
Default Need wiring layout
I need a wiring layout for my Camaro. I took out all the wires for the facotry amp and monsoon amp. I hard wired my deck and used an external amp. I cut the factory connectors off figuring I wouldnt need them again. Well I do. My odometer doesnt work, but I found a power supply that if I hook it up, the odometer works, but every dash light is on. My damn wipers do not work either since I did this. So I thought I would go to GM, get the connector and rewire it. Well, F that, the conector is 84 dollars.
So has any one run into this problem before? Anyone have a wiring diagram that could help me?
Old Aug 16, 2011 | 11:58 PM
tsench's Avatar
i need year make model so i can look it up for u and u need amp wiring layout?
Old Aug 17, 2011 | 02:46 AM
Cosmos's Avatar
Its a 98 z28. I dont need the amp, Im mostly looking for the body. Im thinking I have a ground that isnt connected.
Thanks in advance!
Old Aug 17, 2011 | 01:00 PM
tsench's Avatar
check your pm
Old Aug 17, 2011 | 03:25 PM
Cosmos's Avatar
Pm checked. I dont have IM
Old Jun 6, 2018 | 04:48 AM
02camaross30157's Avatar
Why?!!! Why is it SOOO dang hard to find the dang wiring diagram for head unit and amp?!!! Is it a top secret government protected diagram or what?
Old Jun 6, 2018 | 07:32 AM
WhiteBird00's Avatar
Ungrounded Moderator
The schematics in the factory service manual are copyrighted material from General Motors.
You really felt it was necessary to dig up an almost seven year old thread just to complain? Or do you need to know something about the head unit and amp connections? There are pinout diagrams for both in the Monsoon FAQ sticky.
