bad HID Ballast?
Old Aug 25, 2011 | 08:38 PM
runtwrestlin's Avatar
Default bad HID Ballast?
I have HID headlights in my 97 Camaro. Recently the headlights have started to go off sporadically. I checked the wires for loose connections and didn't find any (but I may need to check more thoroughly.). If the ballast was going bad could it be the culprit? How can I test the ballast to see if it is still good or if it's going out? Thanks in advance.
Old Aug 25, 2011 | 09:46 PM
mrrman's Avatar
Is it one light or both lights acting wierd. If its only one, swiitch the ballasts around to rule out the ballast. If not check the connections.
Old Aug 26, 2011 | 09:18 AM
Previously it was both of them. But recently the left one has been stubborn to turn on. I will try what you said when i get home tonight.
Old Sep 3, 2011 | 06:39 PM
lupers3's Avatar
It could also be a bad bulb too.
Old Sep 4, 2011 | 03:24 PM
cpo's Avatar
cpo
Agreed, switch the ballast around and then the bulbs if necessary to narrow down the fault.
Old Sep 4, 2011 | 03:38 PM
ls1ya's Avatar
How long have you had them? if its starting to flicker and the connections are good, ballast probably going out in a couple days
Old Sep 5, 2011 | 05:41 PM
cpo's Avatar
cpo
Originally Posted by ls1ya
...if its starting to flicker and the connections are good, ballast probably going out in a couple days
Nostradamus.....
