No interior lights anywhere or windows
Do your tail lights (running lights not brake lights) work? The dash lighting gets its power through the IP DIMMER fuse which in turn gets power from the TAIL LPS fuse. If your tail lights aren't working then the TAIL LPS fuse is probably the cause.
A power windows problem may or may not be caused by the BCM but the dash lights certainly are not related. If you have the common solder joint problem in the BCM, your radio will cut out at the same time as the windows. In that case it's an easy fix. If they don't both cut out at the same time then you'll have some more diagnostics to do.
