no power to fog lights
Old Sep 21, 2011 | 10:16 AM
shane0328's Avatar
Default no power to fog lights
so im was putting in some new fog lights and i couldnt get the lights to come on when i touched the wires to them so checked the fuse and took a test light to the wires and there is no power to them so im stumped and i dont really know how to tell if the switch is bad the light on the switch does come on so i assume its good. if you have had this problem before or know whats causing it please reply thank you.
Old Sep 21, 2011 | 12:53 PM
dragonrage's Avatar
You checked what? The fuse? And it was okay? There is also a relay, I believe - did you check that?
Old Sep 21, 2011 | 02:58 PM
shane0328's Avatar
yeah i checked the relay its fine too
Old Sep 21, 2011 | 03:19 PM
VIP1's Avatar
Copy & Paste Moderator
Which fuse did you check. If I remember correctly, the Fog Lights get their power through the TAIL LPS 20amp fuse.
Old Sep 21, 2011 | 07:08 PM
WhiteBird00's Avatar
Ungrounded Moderator
Is your high beam switch on? The fog lights go off when the headlights switch to high beam.
