Where is....
Old Mar 8, 2004 | 08:42 PM
Voided_1's Avatar
Question Where is....
the cd changer connection located in the trunk?
Old Mar 8, 2004 | 09:37 PM
Wildman's Avatar
Driver side rear, directly behind the wheel well.
Old Mar 9, 2004 | 05:37 PM
Voided_1's Avatar
So far all I have found is some sort of valve, do I need to remove some of the trunk interior?
Old Mar 9, 2004 | 05:46 PM
Wildman's Avatar
I take it you have a convertible? The valve is so you can raise the roof manually, just in case the hydraulic motor burns out while your roof is down.
The wires should be visible around there. You may have to remove the carpet panel to find them. If you do not find them after that, your car did not have them installed or they may have been removed (in case of previous owner).
Old Mar 10, 2004 | 05:47 AM
Voided_1's Avatar
Ok, thanks
