At Witt's End with the DRL's
I had a similar issue where one filament was brighter than the other. My turn signal on the side of the dim bulb would stay lit to signal there was an issue with one of the bulbs on that side. It was driving me crazy! I kept swapping bulbs but nothing!
Finally, I disassembled my socket, and sure enough the metal clip wasn't seated properly. After I reassembled the socket, it fixed my problem.
This thread has pics referring to the disassembly of the socket and the metal clip inside that I'm referring to.
It still may be worth confirming the model number on the bulbs if the above doesn't prove anything. Lots of ways two different bulbs can be introduced in to the same package...
What happens when:
- The car is off and the hazzards are on.
- The DRLs are on by themselves.
- The DRLs are on and the driver's turn signal is on.
- The DRLs are on and the passenger's turn signal is on.
- The DRLs are on and the hazzards are on.
- The parking lights are on by themselves.
- The parking lights are on and the driver's turn signal is on.
- The parking lights are on and the passenger's turn signal is on.
- The parking lights are on and the hazzards are on.
Exactly which bulbs did you change? What was the model number of the bulbs you put in? Exactly which sockets did you change? Did you change them by splicing wires? If so, did the colors match up?
But based on the last post, I would guess that the right (passenger) side socket and bulb were replaced and that the wires to the socket are not connected properly. It appears that the parking light (dim) filament is going on when the DRLs are on. That would explain the difference in brightness. I also suspect that the ground wire of the socket isn't connected properly causing the bulb to fail to flash for the hazards or turn signals when the headlights are on (the filaments are grounding through each other rather than to a separate ground path).
