Monsoon Question
Old Dec 11, 2011 | 12:45 PM
Nowhereman's Avatar
Default Monsoon Question
For sometime now I have had the display on my HU not light up.
I just looked at it with some reflective light and noticed that it is still functional, counting down tunes and showing the time.
It just isn't lighting up.
Is it possible that it has a backlight problem?
Maybe I don't need to replace the display itself..
Old Dec 11, 2011 | 08:44 PM
VIP1's Avatar
Copy & Paste Moderator
Here are some threads about Monsoon Display and Lighting issues:
https://ls1tech.com/forums/showthrea...ht=monsoon+led
https://ls1tech.com/forums/showthrea...onsoon+display
Basically it could be 2 issues: a) the bulb blew or b) the solder on the screen's contacts needs to be re-flowed because it has cracked.
Since the display appears to work but just isn't lit, its probably a blown bulb.
If it was a solder problem, the display would appear garbled.
Old Dec 11, 2011 | 09:50 PM
Nowhereman's Avatar
If cold solder joints are the problem, It's as good as fixed.
Ill tear into the HU on Tuesday.
Thanks.
Old Dec 13, 2011 | 09:14 PM
JOHNNY59's Avatar
replace the bulb.
Old Dec 13, 2011 | 09:51 PM
aquariussuperman's Avatar
Replace the entire Monsoon unit with a double DIN and don't look back?
