amp power wire rout help
Old Dec 23, 2011 | 10:17 AM
jbro90's Avatar
Default amp power wire rout help
What is the best place to rout a amp power wire through the fire wall
Old Dec 23, 2011 | 10:58 AM
mrrman's Avatar
I ran mine along the center console then through the opening just above the steering wheel, along the side of the hood to the battery.
Old Dec 23, 2011 | 03:01 PM
pentavolvo's Avatar
passenger side behind pcm under hood
Old Dec 23, 2011 | 03:37 PM
Capricio's Avatar
Yeah, take the PCM out. It's only a couple of screws but it kind of shoe-horns itself into place. Put a rag on your fender so you don't scratch anything when you wrestle with it. Once that's out, you'll have easy access to a nice black rubber grommet that you can shove a power wire through. Be careful not to push the grommet through the FW.
