Rewiring battery terminal cables
Old Dec 26, 2011 | 09:22 PM
Lockdown99ss's Avatar
Default Rewiring battery terminal cables
When it comes to electronics, I am at a loss. I do know that I absolutely hate the side terminal batteries where the terminals get screwed into. My terminals got stripped and that isn't covered in the battery warranty. Any tips before I begin to try rewiring my cables to be applicable for the top "clamp" style batteries? That will be the style of battery I buy next.
Old Dec 26, 2011 | 11:36 PM
94'BLKBRD's Avatar
I used butt connectors to extend my wires in order to use the top posts on my Optima, real easy.
You need some 6 gauge wire, 6 gauge butt connectors and 6 gauge ring connectors.
Also, two of these
http://www.google.com/products/catal...d=0CIoBEPMCMAA
Old Dec 27, 2011 | 08:10 AM
dragonrage's Avatar
If you don't have a car audio system, I suppose you can use butt connectors if you want. I do at least recommend either the kind that make a watertight seal with a heat gun, or shrink wrapping them with ADHESIVE shrink wrap.
If you've got a system then replace the wire completely with 4 gauge or 2 gauge or, if you have a crazy system, 0 gauge.
Old Dec 27, 2011 | 08:21 AM
Predator's Avatar
You could also just replace the screws in the battery cables. They pull out with vise grips. Replacements are a couple bucks.
Old Dec 27, 2011 | 12:44 PM
94'BLKBRD's Avatar
The terminals on the BATTERY were damaged, not the battery bolts.
Old Dec 27, 2011 | 01:31 PM
Predator's Avatar
Oops, I have to work on my reading comprehension skills.
Old Dec 27, 2011 | 03:06 PM
I ended up buying the top post style battery and cutting off the ends of the existing wires. Redid the ends to connect to the clamp style connections. Problem solved. Thanks for the input!
Old Jan 2, 2012 | 01:24 PM
aquariussuperman's Avatar
Any pictures of your work?
