Window motor replacement - how hard and also dynamat question
Old Jan 1, 2012 | 05:41 PM
FSUNole17's Avatar
Default Window motor replacement - how hard and also dynamat question
I am going to need to replace the window motors this spring on my 2002 TA and I had 2 questions. First, is this something I can tackle myself or would I be better off having the dealer do it? I am not by any stretch of the imagination a technician so if it is even remotely involved in terms of wiring, etc., it's probably not for me.
Secondly, I have dynamated my doors pretty extensively and when these are replaced, will they have to cut into my Dynamat to replace these?
Old Jan 1, 2012 | 07:50 PM
VIP1's Avatar
Copy & Paste Moderator
To replace the window motors, you have to drill 3 holes in the inner door skin to see the 3 rivets that need to be drilled to remove the stock motor.
Dynomat only makes it a little more difficult.
Here is the sticky on replacing the window motors.
https://ls1tech.com/forums/2977771-post18.html
You can find more threads in a search.
Old Jan 1, 2012 | 07:55 PM
jaysan's Avatar
Just use duct tape and a rip apart a cardboard box . Bam you have dynamat
Old Jan 1, 2012 | 08:14 PM
sjsingle1's Avatar
the dealer replaces the whole assembly............you can just replace the motor
Old Jan 2, 2012 | 01:36 AM
bill12690's Avatar
Friend of mine had his replaced at a dealer and got raped. If your mechanically inclined at all, I'd HIGHLY suggest doing it yourself, unless you just have money to give to someone. It's really not that hard to change the motor.. dynamat will make it a longer process, but probably worth it in the end.
