hatch speakers problem
but yes as mentioned above it could be a polarity issue (+ and -), but not likely due to the issue...try a different speaker, or try disconnecting your fronts and see if it changes...if it does i'd recommend getting a small 4 ch amp for your fronts and subs, something like an Alpine MRP-F300 retails at $200 but sells for less than $150 all day long, has a built in Hi to low converter, and only requires a $40 8 guage amp kit or a 4 guage is better for an extra $20ish, no rca's or trigger wire necessary..with the speaker level input it has auto turn on...this will improve sound quality and clarity dramatically as well if gain's are set up correctly
the amp wires up, as far as audio signal, between the factory amp and the speakers
