A/C Dash Unit not lighting up?
Thanks for any input and help!
You can also put LED's in there, but if you go that way, be sure to get the 180* units with three led's soldered to the board.
THanks!
There are similar bulbs in the instrument panel behind the steering wheel that have special integral holders. Those are "PC" bulbs, but not what are needed here.
Pic:
http://db.tt/UZRidNXw
My recommendations:
1) Take a deep breath and get comfortable with the possibility that you may brake the bulb and have to pry the thing out with pliers and dental tools...
2) I recommend doing this over a towel or paper towel in case the bulb crushes so you don't get bits everywhere.
3) I first try using a tiny piece of duct tape, fold it over in half to make a "tab" on the end, and then attach the ends to either side of the bulb. Then pull slowly.
4) If that doesn't work, I go to pliers - but that has to be done very carefully, otherwise it will break. (Its very easy to crush the bulb.)
I recall that someone else had a really good idea for this in another thread, but I don't remember what it was.
If the bulb crushes, you can pull the shards/bits out with needle nose pliers. Once the big pieces are out, the flat socket of the bulb will need to be pried out with a dental tool, needle, straightened paper clip, etc.
