Subwoofer occasionally cutting out.
Would it be a fuse/wiring problem, or a problem with the sub itself?
Thanks in advance for any help!
Just try powering everything up and gently wiggle all the wires attached to the amp, see if you can reproduce the cutting out and go from there. I assume the sub has it's own dedicated monoblock.
Are you sure the amp isn't going into protect? Like watching it while it's happening. My 2 channel is doing something similar sound wise and it's the amp. It can go back and forth in and out of protect very quickly.
