Getting ready to upgrade audio...
Head unit: Pioneer DEH-P6000UB (have)
-Dash kit: Metra 99-4000 ($12.99)
-Wiring harness: Metra 70-1858 ($9.99)
-Antenna Adapter: Metra 40-GM10 ($14.99)
Amp: Viper D1200.1 (have)
-Amp kit: Knu Konceptz Complete 4AWG kit ($52.49, have partial)
Subs: (2) 12" Kicker L5 (have)
Box: Subthump T-top box (have)
Now onto a couple of questions...
In my last Firebird, I put the amp above the gas tank. This time, I want to put it under the box where the T-tops used to sit. However, I am unsure if this is advisable. Once the settings are set, there really is no reason to have access to the amp for everyday use. But I'm not sure if this area will cause the amp to overheat, since there is probably little airflow down there. Also, I'm not sure how far down the T-tops sit with the T-top box, but I imagine they wouldn't go down far enough to hit the amp.
Next, front speakers. I have the Monsoon system, so I wouldn't mind keeping the Monsoon amp if it is decent enough to power a new set of front components. I know Kee Audio has a speaker package, but I really only want to upgrade the front set since I have enough bass from the subs to not care about the sail panel speakers, and the hatch speakers are just pointless. I found the CDT CL-61A.2-25 PRO component set, I'm just not sure if the Monsoon amp has enough to make these sound decent. Hell, if you guys want to convince me I should get new sail panel speakers too, I'm willing to listen.
Lastly, my T-top box doesn't seem to fit my new car as well as it did my old. My old car was a '96 Firebird, and my new car is an '02 WS6. The box seems to get caught up on the trunk latch on my new car, is this for some reason bigger on the newer models? I've shot off an e-mail to Subthump, but might as well check here too. I didn't spend much time trying to get it to fit as I was in a hurry. But if anyone can shed any light on this that would be great.
Thanks for any help.
Rear speakers are a waist, they're there solely for fill. If you want a really nice loud front stage I'd get a cheap 4 channel amp and bridge it, like an Alpine MRP-F300 can be had for like $125 and give youleanty of power just for the fronts. Those CDT's wouldn't work because no amp can run bridged at 2 ohms. I like the JL C2's, C3's, Hertz Energy, Hertz High Energy in that order of price
As far as the front components go, I want to keep the stock Monsoon amp if possible. That is why I was looking at the 2ohm set, because I know the stock speakers are 2ohm. Looking to get a second opinion on this, as I don't want to run another aftermarket amp for the front speakers only if I don't have to.
