Mosoon head unit
Old Jun 19, 2012 | 03:07 PM
BackInBlack02's Avatar
Default Mosoon head unit
Are the corvette and F-body delco monsoon HU's the same?
I tried to replace a cassette HU with CD changer with a CD monsoon unit with CD changer but the connector for the cd changer is not the same.
the cassette HU has an extra 4pin connector below the CD changer connector, the CD HU does not have that. Is the a CD unit with matching connectors?
thanks.
Old Jun 20, 2012 | 02:18 AM
Anyone???
I did check the FAQ's....did not find what I'm looking for.
Old Jun 20, 2012 | 06:49 AM
WhiteBird00's Avatar
Ungrounded Moderator
If you're talking about the two vehicles in your signature, they're not Monsoon. The "premium" audio system in a 94 Camaro was Bose. The "premium" system in C5 Corvettes was also Bose but a completely different system from the one used in early 4th generation Camaros. They are not interchangeable.
Old Jun 20, 2012 | 09:27 AM
thanks but no, the monsoon CD HU is not the stock one from my 94, I bought that one to upgrade the stock unit because the CD player went out. The new CD stock unit is the LS style, but its missing one connector. I was expecting all of the LS style HU's to be interchangeable between 4th gen F-bod's and corvettes. Is that not the case?
Old Jun 20, 2012 | 09:36 AM
Yes and no. The "Monsoon" head unit is nothing but an ordinary base audio system Delco radio with an extra label on the face. The thing that makes it a Monsoon system is the external amp and the special speaker configuration. So a Monsoon head unit will work as a replacement in a C5 Corvette that had a base audio system but not in one that had the premium (Bose) audio system.
The Monsoon head unit isn't even totally interchangeable between Chevy and Pontiac versions. Yes, the connectors are basically the same and you can use it but the face color, illumination, and features are different between the models.
Old Jun 20, 2012 | 09:46 AM
Ok, thanks. Do you know where to get and how to identify the C5 Bose CD HU?
Old Jun 20, 2012 | 11:43 AM
LS1121's Avatar
have you checked ebay? I see a **** load of them.
or you can look here on the Corvette forum.
Last edited by WhiteBird00; Jun 20, 2012 at 08:25 PM. Reason: merge consecutive posts
