Under Dash loose cable?
Old Jun 30, 2012 | 12:51 AM
Mrjockos's Avatar
Default Under Dash loose cable?
Hi guys, had my steering wheel changed for a new stock one, the company disconnected the airbag cable under the steering wheel dash. during the installation.
But now I've got some problems with ASR light and ABS light, removed the panel under the steering wheel, evrything looked fine, exept for this: Found a loose cable (2 cable, one connector) , but cant find any place where it should be connected?
What is this cable for?
Old Jun 30, 2012 | 07:11 AM
wssix99's Avatar
Save the manuals!
Not sure on the cable.
Did you have a new airbag installed on the new column? If so, that's probably your ASR problem.
Old Jun 30, 2012 | 08:24 AM
LS1121's Avatar
holy oversized picture Batman. I zoomed out like 6 times and still can't see no cable.
Old Jun 30, 2012 | 09:06 AM
Mrjockos's Avatar
No just switched to my old airbag, just the steering wheel is a "new" stock one. But the ASR and ABS lights has know come of, and everything seems to work normal, strange. It dissaperead when i began to drive.
