HELP! PCM Tach Wire Voltage
Old Jul 11, 2012 | 05:15 PM
LS1 Racing's Avatar
Default HELP! PCM Tach Wire Voltage
I've wired up a window switch and an aftermarket tach in my 2002 Z28. Neither seem to be working. I double checked the wiring and I've confirmed that I've plugged into the pin 10 white wire on the red connector.
When I check the wiring with a voltage meter, I get about .009 to .03 volts at idle with no change when I rev it. That doesn't seem right.
Can anyone verify what voltage I should be seeing at idle?
Old Jul 12, 2012 | 12:02 PM
LS1 Racing's Avatar
Anyone??
Old Jul 12, 2012 | 05:10 PM
emenny81's Avatar
I wired to the white cable on Blue connector pin #10
