Battery voltage
Old Jul 20, 2012 | 09:20 AM
2000z28ss's Avatar
Default Battery voltage
I recently had low voltage(all camaros do from what I've read) so I swapped in a 180 amp escalade alternator, it fixed it a little bit, 12.8-13.2 volts running instead of 12.2-12.6, is there a good re-build kit to up the voltage of the alternator more to bring me closer to 14.2 while running? Kind of sick of low voltage.
Old Jul 22, 2012 | 04:13 PM
wssix99's Avatar
Save the manuals!
Voltage generally has nothing to do with the amperage of your alternator. They all produce the same voltage and have voltage regulators in them that keep things around a constant 13.2V, which is the theoretical max voltage of your battery.
If you have 12.8-13.2 volts, you are in good shape and your battery will be happy.
That being said, if you have too much of a load on your alternator, then you'll see a voltage drop. (You'll always see the voltage drop a few ticks when you turn on the A/C, etc.) If you are stock, you shouldn't see anything like this. Likewise a H.O. alternator like you installed is the way to combat voltage drop - but this should only be needed for a H.O. engine or a car with a lot of electronic accessories.
