Tach in F-Body?
Old Aug 23, 2012 | 01:44 AM
Mangum's Avatar
Default Tach in F-Body?
Are there an output wire anywhere to hook up a Tach in a 2000 SS??? Looking to put an adjustable shift light in as the tach cant keep up..
Thanks
Old Aug 23, 2012 | 07:47 PM
1LOMARO's Avatar
The #10 white wire on the PCM under the passenger side of the dash should take care of what your looking to do.
Old Aug 23, 2012 | 08:00 PM
Nemesis350's Avatar
You can also get a tach signal from the main coil pack plug which seems like what people tend to use for nitrous setups (i guess), but i also prefer the white #10 from the pcm.
Although i'm curious if you can tap into the tach signal from under the dash?
Old Aug 24, 2012 | 06:35 AM
Mangum's Avatar
Thanks Guys!
Old Aug 24, 2012 | 07:13 AM
WhiteBird00's Avatar
Ungrounded Moderator
Clarification... the wire is the white wire in position #10 of the red connector in the PCM which is mounted to the firewall under the hood on the passenger side.
