Gauges in vents!!!
but if you really want to do it then step 1 is to pull the dash apart because there are several things you need to do.
Remove vent tips (the pieces that let you point the air)
get into the duct work and PERMANENTLY block off air flow to those 3 ports (you don't want the "super heat" these cars put out when the heater is on blowing against the back of the gauges)
while the dash is apart run the wires as needed for whatever your new gauges are.
The air vents/directors simply pull out. Just get a good grip and give it a pull.
To wire my gauges I opted to pull the radio out, drill a small hole through the hvac ducting (slowly and with a vacuum hose nearby to suck up any debris, go slow enough and you wont get a single bit of debris down the ductworks) You can seal up the hole around the wires once they're ran with some silicone or you can buy a gromet if you can find one that works for your wires.
Takes about 20min to install the gauges and route the wires. Dont worry about PERMANENTLY blocking off your ducting. The gauges will block the airflow and in turn divert the air more towards the side vents.
