Help, headlights won't come on!
.The lights don't come on automatically when I take down the E break anymore like They used to. I try to turn the switch manually to make the headlights come on but the gauges light up, the fogs come on and the running lights come on but the headlights themselves won't come on either low beams or high beams. I put in a new dimmer switch to see if that was the problem and it wasn't. Before that I checked the fuses under the hood to check the headlights but the two slots next to the horn slot where the headlight fuses are supposed to go are empty. I take the fuses out of my friends Trans Am to put them into My Camaro but no luck but then I also noticed that his slot's have both pins on both sides for where the fuse plugs in and mine doesn't....i don't know if that matters and he said those slots are only for the Trans Am pop-up headlights. I heard there is a headlight relay under the dash behind the radio but could that really be the problem? Any help is greatly appreciated. Thanks -Alex
