Clockspring help
Old Dec 29, 2012 | 04:57 PM
Chawlz's Avatar
Hey everybody. I have an 05 gto. Airbag light has been on since purchase and I believe it is the clockspring. I removed it and checked continuity from yellow clip that plugs into airbag to the pins on connector on back of clockspring. Wires have continuity through the whole unit, so I know clockspring itself is good, but there isn't any continuity between one of the wires going into yellow connector, and the pin that actually pushes onto airbag. I was able to pry the back of connector apart to expose the insides, and on that wire, it goes into a little yellow box. (Resistor?) Before going to the pin, that is where it loses continuity.
So is that box bad, am I testing it wrong, can it be replaced?
Last edited by WhiteBird00; Dec 31, 2012 at 12:24 PM. Reason: Merge consecutive posts
Old Dec 30, 2012 | 10:46 AM
wssix99's Avatar
Save the manuals!
Why do you believe this? When this happens with a used car, the thing has usually been in an accident and repaired incorrectly. Have you had the SIR module scanned for codes? (That will tell you where the problem is.)
Old Dec 30, 2012 | 12:11 PM
Chawlz's Avatar
Guy I bought car from said airbag light started coming on when he had someone replace ignition lock cylinder. Steering wheel (and maybe clockspring) was removed. I brought it to dealer to reset/check for codes, the tech said that it won't reset, and it isn't showing any codes...
I need to know if I'm testing this properly because I don't want to spend bunch of $ on clockspring, and not fix problem.
Old Dec 30, 2012 | 04:18 PM
wssix99's Avatar
Save the manuals!
If you have a light on, you have a code. The dealer's tech probably didn't know what he/she was doing. The codes for this light are in a separate module but should have come up on their Tech II.
I think you are good to be cautious with this. The last owner's "guy" could have done anything. For example, if they swapped the steering column, air bag, or even stole the good old airbag, there are other issues to be dealt with.
Very odd that the dealer couldn't quickly point to what was wrong... I'd take it back and talk to a senior tech about it.
