6x9?
Old Jan 10, 2013 | 04:52 PM
youcancallme29's Avatar
Default 6x9?
I know the rear hatch speakers are only 4" speakers. Will modifying the panels for a 6x9 or 5x7 give a fuller sound? Or is the signal from the monsoon amp not strong enough to power anything more than the 4" speakers?
Old Jan 10, 2013 | 05:03 PM
chaman's Avatar
Old Jan 10, 2013 | 06:42 PM
54 what?
Old Jan 10, 2013 | 06:43 PM
chaman's Avatar
6x9=54.....LOL!
Old Jan 10, 2013 | 07:44 PM
Capricio's Avatar
http://www.mobileaudio.com/rac-faq/rac-faq_5.html#SEC95
5.5 What is "rear fill", and how do I effectively use it? [HK, JSC]
Rear fill refers to the presence of depth and ambiance in music. A properly designed system using two channels will reproduce original rear fill on the source without rear high frequency drivers. Since recordings are made in two channels, that is all you will need to reproduce it. What is captured at the recording session (coincident pair mics, Blumlein mic patterns, etc.) by a two channel mic array will capture the so called rear fill or ambiance. Many of the winning IASCA vehicles have no rear high frequency drivers. Also a lot of this has to do with system tuning. If rear high frequency drivers are added, however, the power level of the rear fill speakers should be lower than that of the front speakers, or else you will lose your front-primary staging, which is not what you want (when was the last time you went to a concert and stood backwards?). The proper amount of amplification for rear fill speakers is the point where you can just barely detect their presence while sitting in the front seat. Separates are not a requirement for rear fill; in fact, you may be better of with a pair of coaxial speakers, as separates may throw off your staging.
Old Jan 10, 2013 | 10:30 PM
Now thas a fantastic answer thanks
