Help Finding a Connector
Old Jan 11, 2013 | 10:37 PM
Robofuzz's Avatar
Default Help Finding a Connector
I am needing to find a connector that will replace the switch in the attached picture. This switch is the fuel door switch from a 2005 GTO. I am wanting to create an extension harness of sorts and make it plug and play. Any thoughts on how to identify what connector to get? And, yes, I have browsed Mouser and some other sites and have not seen something that looks like it will work.
Any help is appreciated.
Old Jan 11, 2013 | 11:34 PM
Mista Blazer's Avatar
Other the custom fabrication. I don't think there would be, what I would do is run wires for each pin to desired location then find a way to tuck the wires away, bundling them together. But as far as a extension harness I don't think anyone currently makes them
Edit: are you talking about hooking up a whole new switch all together?
Old Jan 12, 2013 | 12:06 PM
wssix99's Avatar
Save the manuals!
It will be easier to figure out by taking a picture of the plug and not the switch. Once you can identify what type of plug it is, then you can easily look up the matching receptacle, which will look different from the switch socket.
Most GM's are easy to look this stuff up, but since the GTO started as a Holden, I'm not sure if they used the same Delphi connector systems. If they did, it should be a sinch and the plug should be in the Delphi catalog.
Old Jan 14, 2013 | 09:16 AM
Robofuzz's Avatar
Thanks. I'll look in the Delphi catalog. I know that the engine harness uses Delphi connectors.
If I needed to make something, where can I get mini spade connectors? I could make something myself to plug into the harness, but the spade connectors would need to be about the size of the spades on the mini fuses, if that makes sense.
Old Jan 14, 2013 | 10:11 AM
My local O'reilly carries them, you may have to modify the connector a little but. such as smushing it to make a tighter fit. i had to do that in my girls 93' camaro and i havnt had any issues out of it yet. what i would do is, take your switch with you and mock up the connectors, O'rielly's is really the only place that i have been able to let me open the package and test fit things. but then again im in there every other day so they know me better then most people. just let them know what you are doing before you help yourself haah
