tail lights
Old Feb 10, 2013 | 09:12 PM
brandon9598's Avatar
Default tail lights
I noticed something interesting a while back. My friends ss has 4 lights that come on in his tail lights. 4 when lights are on, and two on the inside when brakes are applied. Mine only have the two on the inside light up with or without brakes applied. Why is that?
Old Feb 10, 2013 | 10:00 PM
Daniel Richards's Avatar
bulb layout (assuming same as firebird) should be a single 194 (like the side markers) on the outside and then the 2 dual filament bulbs (for both parking lights and brake lights) then there is the reverse light. pull you lenses and check for burned out bulbs.
Edit: ok just found some pictures of the back side of Camaro lenses, there are 4 bulbs total, 1 for reverse, 1 for turn and from the "sockets" in the plastic I would say one for the brake and then a 194 on the outside, advice from above still applies.
