High beams work about half the time..
I do recall reading in a thread that some states/counties that it is illegal to.have more then 4lights in one direction. Meaning more then 4 of the same color.
As far as the bulbs go and shutting off after a few seconds, it sounds like a relay issue.might run to orielys or auto zone and test a new relay to see If it fixes if it doesn't I'd look at replacing the bulbs. If that doesn't work then it most likely sounds like.a wire issue, but I doubt that since they worked before
I would check the bulb socket for loose or corroded connections since it's an intermittent problem.
