Amp for 2 JL 10w3s?
OP if my previous statement is correct then what you are looking for is an amp (preferably monoblock) that is atleast 2 ohm stable (not 2 ohm STEREO stable, if you go 2 channel amp and not monoblock) with a max output of 2000 watts at 2 ohm, I personally feel Autotek is an excellent bang for the buck (pun intended) you could do the Autotek M2500.1D it is compact yet powerfull (would put 1250 watts peak at 2 ohm) and since it's 1 ohm stable you pretty much can't overheat it at 2 ohm (believe me I've tried) and it leaves you open to getting dual voice coil subs and going to 1 ohm for peak output down the road (which is what I will have done as soon as I build my new box and it can be found for around 150 dollars which is hard to beat if you ask me.
