is this possible?
Old Apr 19, 2004 | 10:41 PM
zchgla's Avatar
Default is this possible?
i have a factory 12 disc changer, and my head unit dosent have a cd player, but a casette player. i would like to take out my 12 disc changer and also replace my headunit with one that has a cd player. is it possible to replace my head unit from a head unit from another camaro?
Old Apr 20, 2004 | 10:34 AM
slow's Avatar
yes, but you will need a 2000 or newer to make sure the CD player will control the changer, some 99's (MAY) work, but its a gamble.
Old Apr 22, 2004 | 09:47 PM
zchgla's Avatar
well, i plan on taking out my 12 disc. so i dont need one to control a changer. my car is a 98, will a factory headunit out of a 99 trans am work?
Old Apr 23, 2004 | 08:11 AM
WhiteBird00's Avatar
Ungrounded Moderator
Well, yes it will work but it will be gray instead of black and will have orange/red illumination instead of blue/white. The Camaro radio had automatic volume control which wasn't on the Firebird version but the Firebird had a graphic equalizer that the Camaro didn't. The mounting and the wire harness connectors were the same but the radios were somewhat different.
Old Apr 23, 2004 | 03:30 PM
zchgla's Avatar
how much will an audio place charge for replacing head units and taking out a 12 disc changer? and where would i be able to find one? a junk yard?
Old Apr 24, 2004 | 07:21 PM
Why pay someone to do something you can do yourself in about 15 minutes? You can unbolt and remove the CD changer and just tuck the harness up under the trim panel near the left rear speaker (that's where the harness is stored on cars that don't have a changer).
The radio is held in with only three screws. Carefully pry off the trim panel, remove the screws using a 7mm socket and pull the radio out. Unplug the harness and antenna, plug in the replacement radio, push it back into the dash, put in the screws and push on the trim panel. That's all there is to it.
You can probably get a good deal on a replacement head unit on ebay. Lots of people sell them when they upgrade to an aftermarket system.
