replacing interrior speakers
Old Apr 4, 2013 | 03:38 PM
Fraser2000's Avatar
Default replacing interrior speakers
Does anyone have a trick to getting to door panels off I'm breaking tabs off them like crazy... Or any tricks period to replacing all the speakers.... Thanks
Old Apr 4, 2013 | 05:18 PM
Daniel Richards's Avatar
doors are easy to get off, the exact process varies slightly between the Camaros and Firebirds.
Start by rolling your windows all the way down, remove the power window switch plate from the door and unplug the wires then remove the screw from the trim piece behind the door handle, with these out of the way you now have access to all the locations of the 4 BIG LONG screws remove all of then and pull the panel UP and toward you.
