Please help!!!
Old May 2, 2013 | 04:47 PM
Lances02ss's Avatar
Default Please help!!!
I took an old Clifford alarm from my car because the key pad went and I was just going to get rid of it all together, so I carefully took it out made sure all wires from the stock harness were reconnected and test my power to the starter and fuel pump it all works fuel pump primes starter gets voltage but the car doesn't even attempt to start. Im at a loss any help would be greatly appreciated
2002 ss Camaro m6
Old May 4, 2013 | 07:26 AM
WhiteBird00's Avatar
Ungrounded Moderator
I would guess that you have a VATS problem. Is the SECURITY light in the instrument cluster on or flashing? The alarm system you removed may have included a VATS bypass that is no longer working. That means the BCM will not provide ground for the starter relay and it will not crank despite having power.
