Major electrical problem need help!!
Old May 26, 2013 | 03:29 PM
Z28Dave's Avatar
Default Major electrical problem need help!!
alright so this all started after i destroyed my drivetrain with my turbo but now my car has turned into a electrical nightmare.
if the car is running and i so much honk the horn the motor will shut off
when i switch my headlights on the high beams come on with the low beams but on my passenger side its weak and dim.
if i flash my high beams sometimes the car will die
i have no clue the extent of working on the electrical system was tapping into the fuel pump with the harness STS provided but after removal of the kit it works no problem except when above mentioned actions.
what could be the problem? a bad ground? perhap maybe some wired melted and fused with another? i checked every relay to ensure proper functionality, double checked every fuse.
what all would i need to replace everything? i'm swapping the H/C/I soon and would like to fix every electrical problem i have
Old May 27, 2013 | 04:23 PM
Neenjah's Avatar
*DISCLAIMER*
I have no ******* clue what I am talking about.
Id check grounds under the hood. I know a few people including me who have had all sorts of stupid electrical issues and it ended up being a ground under the hood. where it be PCM or body to engine.
Thats all I got brah.
