1995 Key Fob Help Please!
Old Jun 4, 2013 | 12:04 PM
Silver2000WS-6's Avatar
Default 1995 Key Fob Help Please!
So a while back I bought a key fob for my 1995 Trans AM. It was in very good shape and was supposedly never used and it doesn't look like it has been. Since it was so old I went ahead and replaced the batteries. The car did not come to me with a key fob, but it did have the AUO code "or whatever everyone said to look for." So I followed these instructions to program it.
http://shbox.com/1/4th_gen_tech2.html#1995keyless
However the car never would make a sound and the remote would not program. It was like the car was not sensing I was jumping the wires because the door lock actuators never did cycle. After doing a lot of research it appears that some cars have had the "transmitter or module" that receives the signal removed. However I removed the passenger side kick panel and inspected the module. I did not see any noticeable damage to it and everything was plugged in. Also I inspected the OBD port and all of the terminals were in good shape and I was making contact with the jumper wire. Has anyone else ever had this problem? I would appreciate any help.
Thanks,
Chase
Old Jun 17, 2013 | 03:15 PM
shbox's Avatar
If you have verified power and ground are getting to the receiver and that the program input lead has continuity from the DLC to the receiver, I would guess the receiver is bad.
http://shbox.com/1/keyless_schematic.jpg
Old Jun 17, 2013 | 09:19 PM
Thanks, I will start there.
