Hepl wiring Alpine CDA 9835
Im not going with the wiring harness since I will be using the pre-amp outsputs for all the speakers and my subs. So basicaly I just need to indentify the following wires, if you can help, I greatly appreciate it.
Illumination Lead: Vehicles instrument cluster illumination.
Switched Power: Wire providing +12v only when vehicle is turned on
Power Antenna: +B Teminal of the power antenna
I think that should cover it.
The owners manual doesnt say it anywhere but I thought I read on a web site somewhere that the CDA-9835 needs an amp install kit for the power supply since it draws so much power. Anyone know if this is the case? or can I just use the power lead thats already there from the stock radio.
http://www.houston-f-body.org/tech/monsoon/
It'll tell you where to find the leads that you need.
I dont know about the power draw of that Alpine. All I can suggest is to check out its power requirements and compare it to the rating on the fuse in the fuse block that corresponds to the radio. Be aware that other devices may be on that circuit as well.
--VIP1
