Best place in firewall to run the power wire?
Old Jul 15, 2013 | 01:25 PM
IrbyBocksnick's Avatar
Default Best place in firewall to run the power wire?
I need to know a good spot to drill to run my power wire through the firewall. Definitely don't want to drill through anything important.
Old Jul 15, 2013 | 04:36 PM
(SS)'s Avatar
Unbolt and move the computer out the way.Drill there.
Old Jul 15, 2013 | 05:31 PM
WhiteBird00's Avatar
Ungrounded Moderator
First, do a search...
Then... don't drill - use the existing grommet through the firewall under the PCM on the passenger's side, like the hundreds of others who have asked the same question have done.
Old Jul 15, 2013 | 10:07 PM
Daniel Richards's Avatar
+1, although I had a hell of time getting the computer back in place, took some wrestling but I got it.
Old Jul 16, 2013 | 12:11 AM
Ok, sounds good. Will do.
Old Aug 3, 2013 | 10:44 PM
Is the grommet behind the pcm really the easiest way? I've heard stories about it being a pain to get the pcm back in place once the job is done. Reason I asked is that I have everything else done on my install and now I'm bout to run the power wire. Seems like it would just be easier to drill a hole and put in a new grommet. No hassling with the pcm. But what do I know? I'm still a novice on Fbodies.
Old Aug 7, 2013 | 11:37 PM
I did like you said guys. Was a bitching putting that pcm back in but got it in there. System sounds very good now.
