Using monsoon amp for alpine type-r
Old Jul 27, 2013 | 11:41 PM
pHEnomIC's Avatar
Default Using monsoon amp for alpine type-r
I have some alpine type-r 2 ways in my doors wired straight to a decent 50x4 aftermarket headunit. There just isnt enough power and i dont want to add any weight to the car. I was going to try to find a 3 channel amp to do both doors and my sub but they are expensive.
Should I try using the monsoon amp to power the speakers? Is it decent and will it be an improvement?? My car is loud and sound quality is important but obviously theres a limit to how much you can do in this setting.
Old Jul 29, 2013 | 08:40 AM
WhiteBird00's Avatar
Ungrounded Moderator
There are a number of factors involved here but the short answer is no, the Monsoon amp won't really help.
First, your HU does not produce 50x4... it probably produces 50 watts per channel peak but only about 18 watts per channel RMS. That means that the Monsoon amp produces about twice as much power. However, it take ten times as much power to double the output volume. Doubling power only increases volume by about 3dB or about one click of the volume ****.
The Monsoon amp is decent for what it does but it's not particularly powerful and it has a unique configuration of filtering for its eight channels of output. Using it to gain just one click on the volume **** seems hardly worth the trouble - especially since it won't work very well with your coaxial speakers.
Old Jul 29, 2013 | 10:21 PM
pHEnomIC's Avatar
As it turns out I realized i did run it through the monsoon. I am gonna try to go headunit straight to speakers to see if it is a cleaner signal.
Old Jul 30, 2013 | 05:33 AM
IrbyBocksnick's Avatar
You should be getting clean sound as is. I don't really have any gripes about the stock monsoon amp. Seems to do it's purpose. Fairly clean, just not super high wattage. It's going to have at least twice the wattage of the stock deck.
Old Jul 31, 2013 | 02:20 AM
99Bluz28's Avatar
I'd run at least a 50 watts rms per channel power amp to overcome the loud exhaust without distorting the speakers. Take a look at some 4channel amps you should be able to get one under $180 (shipped) that has plenty of power for your Alpine door speakers and your subwoofer.
