Tweeters with coaxial simple question!
The amp can be used on 2 or 4 ohms. I know people usually wire tweeters in parallel but here since both mine are 2 ohm can I just wore tem in series with the coaxial and then get a 4 ohm load to te amp? From my understanding the amp would still see a 2 ohm load until the crossover for the tweeter kicks in
I'm also curious why you wan't more highs with your set up? What is your crossover on your amp set at for those kappas or are you running them full range? Those kappas are so post to have really really good clean loud highs from all the reviews I've read on them. Make sure the buttons on the 62.9i tweeters are at 0db and not -3db.
I'm installing a JL XD400/4 and four 62.9i kappas I bought 2 weeks ago, so I hope they have loud clean highs.
Another way to go would be to delete your hatch speakers and bridge your JL amp. Bridge channel 1&2 for the front right then bridge channel 3&4 for the front left. That would give you 200 watts into a 4ohm load for each side. Then you could use your tweeters you bought and wire them in series to 4ohms for the fronts and still have channels 5&6 for your sail speakers. Hope this helps you out and gets you the front highs you're wanting.
