Speaker Question
Old Aug 31, 2013 | 03:00 PM
TurbopigB4C's Avatar
Default Speaker Question
I have a set of old school MB Quart 5.25" component speakers circa 2001 that were pretty pricey at the time and were still made in Germany I believe that are 90w. Would it be stupid to use these as front door speakers rather than a 6.5 component setup with adapters in a amplified 6 channel set up on an 01 ss?
Old Aug 31, 2013 | 05:14 PM
Daniel Richards's Avatar
you could use them if you want but you'll need to build custom mounts because the doors are 6.5", most will say its a bad idea because 6.5" typically have a wider frequency response and higher power handling, albeit not much but there is some. If you have them and don't mind building adapters to get them to fit then go for it.
Old Aug 31, 2013 | 10:04 PM
Capricio's Avatar
http://www.scosche.com/catalogsearch...t/?q=SAU56&ok=
