alternator question
Old Sep 13, 2013 | 09:59 PM
jt_2002_ta's Avatar
Default alternator question
this may be a dumb question but gonna ask anyway... could a weak alternator cause a performance problem?
Old Sep 14, 2013 | 12:11 AM
Daniel Richards's Avatar
to some extent YES, the electrical system is VITAL, if the voltage/current is to low then the ignition system is less efficient (less spark from the plugs) which means less fuel burned and crappier mileage and performance, now as to how much an extent is the question.
Old Sep 14, 2013 | 06:27 AM
wssix99's Avatar
Save the manuals!
There's really no such thing as a "weak" alternator. They are either good (working to spec) or bad (not working to spec)
If you have a performance problem related to the electrical system, you should see a voltage drop, which should be evident on your gauges. If you have done some modification to your car that would make your alternator undersized, (you are probably sized just fine) you'd see a drop also.
Bad alternators can cause your voltage to drop but so can a number of other things on the car. Short circuits, corroded wires/cables, etc.
Its either good or its bad. The alternator produces more If alternator can charge the battery to a point that it can crank the carproduces plenty of power to
Old Sep 15, 2013 | 09:08 AM
jt_2002_ta's Avatar
took car to local parts store and tested it on car and its very erratic in its readings. bounces between 13.5 and 11. battery is brand new and tested fine. my other question now is fuel pressure at the rail at idle is right around 55psi and wot drops to around 50-52psi. so im assuming if the fuel pump isnt getting enough voltage pressure would drop under load correct?
Old Sep 15, 2013 | 10:29 AM
wssix99's Avatar
Save the manuals!
Sounds like a bad voltage regulator - time for a new alternator.
I'm not sure what normal is, but connecting a fuel pressure fluctuation to overall voltage of the car is a stretch. You'd have to monitor pressure at the pump to confirm. There are lots of other regulating elements and constrictions (fuel filter, etc.) that could also be problematic.
