Factory Cassette to Factory CD
Old Sep 23, 2013 | 09:40 AM
Spd-Kilz's Avatar
Default Factory Cassette to Factory CD
I have 1998 Camaro that has a factory cassette headunit. I would like to 'upgrade' to a factory Delco CD player headunit. Does it matter what CD headunit I buy? Monsoon/Delco etc?
Cheers
Old Sep 24, 2013 | 08:07 AM
WhiteBird00's Avatar
Ungrounded Moderator
This is covered in the Monsoon FAQ sticky at the top of the section but basically there is nothing special about Monsoon head units - they're just ordinary Delco head units with a Monsoon label on the front (many of them don't even have that). If you have a factory CD changer, you must get a CD HU from a 2000 or newer model to maintain compatibility with the changer. You probably should get a 2000 or newer HU anyway because you may want to add one of the aftermarket auxiliary input adapters and they all require CD changer compatibility.
Old Sep 28, 2013 | 04:29 PM
BandDirector Blk98ZM6's Avatar
What he said ^ However, also please be aware that the ebony interior color of the '00-'02 F-Body is different than the graphite interior color of the '97-'99 F-Body. I also had CS in my '98, but I also had a Monsoon CD changer. I ended up buying an Monsoon CD HU out of a an '00-'02 and then also bought a '98 CD HU as well and swapped the stock faceplates so that they would match AND I could control my changer. I then put the one I wasn't using back up on eBay (being honest about the color difference) and recovered most of my investment.
