Need help with charging system
Old Oct 7, 2013 | 12:50 PM
rsoetidjo's Avatar
Default Need help with charging system
I just moved my alternator to the other side (driver), because it wont clear the valve cover. And I add about 2 feet of wire. And now the battery wont charge anymore. It' show around 8-10volt. normal like 12-14. What do you guys think? I used a 8 gauge wire.
Old Oct 7, 2013 | 03:14 PM
Daniel Richards's Avatar
personally I think 8 gauge is to small for that wire but I don't think that is your issue, is the belt tension good and did you hook up the exciter wire?
Old Oct 8, 2013 | 02:43 PM
rsoetidjo's Avatar
Belt tension is good. Exciter wire good
Old Oct 10, 2013 | 02:08 PM
rsoetidjo's Avatar
I found out that on the battery say 13.5 with a voltmeter, but on the gauge in the dash say only 12
