pac oem 1
Old May 10, 2004 | 05:58 PM
pushinfreight's Avatar
Default pac oem 1
Does anyone know where I can see what this is and if it is readily avail at local stereo shops? Also, once this is connected is this all I need to run signal to an amp for a sub? As far as I can tell from a search is that I need to use this so that I can run rca cables to the amp for signal and I can tap the power source from the power antenna. If I am wrong someone please correct me.
Old May 13, 2004 | 12:08 PM
TA TED's Avatar
STF Veteran
http://www.pac-audio.com/products/oem1.htm
