Throttle Gauge?
Old Feb 24, 2014 | 08:04 PM
LSX Man's Avatar
Default Throttle Gauge?
Ok guys,
I'm in the process of installing a lot of higher end and modern pieces to my 91 Camaro.
The new Nissan GTR and a few other super cars have a throttle gauge. Pointless? Arguably. But its cool.
I will be buying a few digital 60mm gauges for my car, and I would like a throttle gauge, and unfortunately no one makes aftermarket gauges. I don't think I can call up Bugatti, and ask for the parts department either.
I am thinking that I might be able to use the TPS sensor somehow(LS1). Or rig up, well in proper terms, design a mechanism that is attached to the gas pedal that will give more voltage as the pedal is pressed, and this voltage then goes to the gauge, allowing the needle to move.
I'm sure I will need a regulator of some sort between the pedal and the gauge, unless full 12 volts allows the needle to be fully turned.
The line of gauges I am interested in use a Stepper motor. The company sells these gauges:
Boost Gauge
Water Temp
Exhaust Temp
Oil Temp
Oil Pressure
Any ideas on where to start? Whether that be using the TPS sensor, or designing a device that correlates pedal position with voltage?
Old Feb 25, 2014 | 02:02 PM
Streetlegal?'s Avatar
I think you would be best off using the TPS like you said. Then you may need to use a circuit to convert the output voltage to whatever you want the output to be.
Old Feb 25, 2014 | 04:50 PM
tylerdietzenbach's Avatar
TPS is the best choice here. Shouldn't be an issue splicing into that, however way you prefer.
