1999 Firebird Lighting
UPDATE:::: it was a blown 5amp fuse listed under IP Dimmer. thanks everyone.
this also fixed my now working cluster lights.
Backprobe the brown wire at the stop lamp connector and supply it a good ground. Step on the brake. If you've got 11.5 to 12ish volts your voltage supply is good if not then you've got a high resistance in the power wire and you'll need to find the spot. If it's good then back probe the brown wire and blk wire and the connector. If it's low you'll need to look at ground G400. Clean the ground. If that doesn't do anything then follow the black wire to it's splice point S410 and redo the splice.
If you hate wiring bring it to a shop.
Last edited by tryintogofast; Mar 6, 2014 at 04:54 PM. Reason: Further explaination
Oh, and when he says "back probe the brown wire" he means using a test light or multimeter. Don't just give the brown wire a "good ground" - you'll short the tail lamps circuit and blow the fuse.
