Help with wiring
Old Mar 13, 2014 | 03:52 PM
WCT13's Avatar
Default Help with wiring
I just bought a humount bracket, and I want to wire it up, but...idk where to wire it to.
Its a cluster F*@& in their.
All the bracket has is a red one thats supposed to go to the dimmer and the ground.
Attached Thumbnails Help with wiring-1.jpg   Help with wiring-2.jpg   Help with wiring-3.jpg
Old Mar 13, 2014 | 04:23 PM
WhiteBird00's Avatar
Ungrounded Moderator
Someone (hopefully not you) appears to have butchered the factory wiring to install the aftermarket head unit. That's such a shame since a $10 wire harness adapter would have made the HU plug into the factory harness without any cutting.
You can still fix it if you are so inclined. Get Metra adapter 71-1858 to repair the factory harness and replace the connector that was cut off. Then get Metra adapter 70-1858 to finish the aftermarket HU wires so that it will plug into your repaired harness.
Otherwise, if you prefer to leave it butchered like that, look for the gray wire from the factory wiring and connect it to the red wire of the humount. Then look for the black wire from the factory wiring and connect it to the black wire of the humount.
Old Mar 13, 2014 | 05:02 PM
WCT13's Avatar
Nah, it was the previous owner. We found it, its not the gray though, its the red one. they got crossed somewhere.
