Power Cables 2002 Camaro SS Convertable
Old Apr 12, 2014 | 10:20 PM
Smokin02's Avatar
Default Power Cables 2002 Camaro SS Convertable
Greetings! Looking for ideas on routing of power cables for 600 W Kicker amp. Purchased 4 gauge kicker power cables, 17 ft long. Looking at the vehicle, I'm not sure where to pull the power cable through the vehicle. Looking under the hood and it's real crowded...couldn't see an access point through the firewall. Any recommendations for routing? I was considering running it through the front fender...really not sure as I just looked at it tonight. Thx
Old Apr 13, 2014 | 09:19 PM
01WS6/tamu's Avatar
Run it down passenger side under carpet. Pull the kick panel and you will see where the factory harness goes through the firewall. Pull the pcm and bracket out under the hood and you will have access to pull wiring the hole must be drilled from inside out. Be sure to seal cable entrance with silicone or it will leak water every time it rains.
Old Apr 13, 2014 | 09:43 PM
xenergyx's Avatar
Theres already a hole wide enough to put 2 0gauge wires threw although you went over kill on your power wire 8 would have been plenty it is just a kicker
