Deleting unused harnesses
Old May 15, 2014 | 10:48 AM
ss performance's Avatar
Default Deleting unused harnesses
I am deleting the AIR & ABS in my 02 Camaro.
I would like to remove the harnesses for them and any others that are unused.
I would prefer to remove them not simply cut them. I would like to be able to remove the wires from connectors where they enter other harnesses or go thru the fire wall.
The actual removal I can do I have the pin removal tools.
I don't want to have water getting into the connectors so what I am trying to find is the plugs to insert where I remove the wires.
Does anyone know where I can get the plugs? I know different types of connectors use different plugs.
Any info would be greatly appreciated.
Old May 16, 2014 | 10:15 AM
wssix99's Avatar
Save the manuals!
Please don't bump threads within 24 hours. The answers will come but most folks aren't on here all day long.
You can find the plug part numbers here: http://delphi.com/pdf/contact/brochu...balCatalog.pdf
Mouser is usually a good place to get these uncommon components.
